[gdal-dev] Bug in of GDALRead.cs
Frank Warmerdam
warmerdam at pobox.com
Thu May 9 10:51:23 PDT 2013
Markus,
Ah, I see. The up to date sample scripts can also be found at:
http://svn.osgeo.org/gdal/trunk/gdal/swig/csharp/apps/
The examples in FWTools are likely very out of date.
Best regards,
Frank
On Wed, May 8, 2013 at 6:57 PM, markus.u.mueller
<markus.u.mueller at zoho.com>wrote:
> Frank,
> that is what I am using (Tamas' SDK), perhaps my email was not clear
> enough. The example .cs files (and that is where I found the bug) though
> are only available via FWTools. Makes sense?
> This example files are not strictly part of the C#-bindings, but as they
> are the only documentation available I figured it makes sense to fix them.
> Cheers,
> Markus
> ---- On Wed, 08 May 2013 15:57:05 -0700 *Frank Warmerdam <
> warmerdam at pobox.com>* wrote ----
> Markus,
> The GDAL C# bindings in FWTools is pretty ancient at this point so
> reporting bugs against it is unlikely to result in improvements. You might
> want to upgrade to the latest version - either building from source, or
> perhaps using Tamas' SDK (http://www.gisinternals.com/sdk/).
> Best regards,
> Frank
> On Wed, May 8, 2013 at 3:07 PM, markus.u.mueller <
> markus.u.mueller at zoho.com> wrote:
> Dear listers,
> I think I found a bug in GDALReadDirect.cs (part of FWTools). Is this the
> right place to record it? I will describe the problem anyway and would be
> willing to move it to another place if more appropriate.
> I want to read Arc/Info Binary Grids and convert them to other image
> formats using the C#-bindings of GDAL. I installed FWTools 2.4.7 and the
> current binaries (MSVC2010 (Win64) -stable) from
> http://vbkto.dyndns.org/sdk/. Then I started testing the example
> C#-programs that are part of FWTools, especially GDALReadDirect.cs. When I
> use the demo dataset utm.tif, this all works fine.
> I then converted utm.tif to the Arc/Info Binary Grid format using ArcMap
> 10 (Conversion Tools - To Raster - Raster to other Format). When I try to
> use GDALReadDirect.cs I get the following error messages:
> Using driver Arc/Info Binary Grid Band 1 : DataType: GDT_Int16 Size (512,512) PaletteInterp: GCI_Undefined OverView 0 : DataType: GDT_Int16 Size (256,256) PaletteInterp: GCI_GrayIndex OverView 1 : DataType: GDT_Int16 Size (128,128) PaletteInterp: GCI_GrayIndex The number of the raster bands is not enough to run this sample
> GDALReadDirect.cs obviously has an erroneous method named
> SaveBitMapDirect, that first checks on the available Color interpretation
> and then on the number of bands. After the file is converted to Arc/Info
> binary Grid format, the information about the Color interpretation is lost,
> so only then the program checks on the number of available bands and
> returns an error message. SaveBitMapDirect works for the described case
> if Line 157 is edited:
> if (redBand.GetRasterColorInterpretation() == ColorInterp.GCI_GrayIndex ||
> redBand.GetRasterColorInterpretation() == ColorInterp.GCI_Undefined)
> This is not a general fix, only for the immediate problem.
> Cheers,
> Markus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130509/13f3c896/attachment.html>
