Le 13/05/2013 17:23, Tyler Mitchell a écrit : > Hi Benoit, you'll probably have more luck if you ask on the QGIS > mailing list, as GDAL helps with data access but not with the > visualisation you are aiming for. Ok, thank you. Benoît
