[gdal-dev] Can't build gdal in x64
Mihaela Gaspar mihaela.gaspar at urbanrobotics.net
Mon May 13 11:59:35 PDT 2013
The solution from Joaquim Luis worked.
I used
call "C:\Program Files (x86)\Microsoft Visual Studio
10.0\VC\vcvarsall.bat" amd64
Thank you !
On Mon, May 13, 2013 at 11:51 AM, Mihaela Gaspar <
mihaela.gaspar at urbanrobotics.net> wrote:
> Thank you.
> I have all the dependent libraries built in Win32 and x64, and have set
> the correct paths to platform/configuration
> Also, pls see my question update - before building, I run a clean.
> On Mon, May 13, 2013 at 11:43 AM, Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
>> On 2013-05-13 12:53 PM, Mihaela Gaspar wrote:
>> > In x64,I get linker errors:
>> > |LINK : error LNK2001: unresolved external symbol _OGRFeatureStylePuller
>> > LINK : error LNK2001: unresolved external symbol _OSRValidate
>> > gdal19.dll : fatal error LNK1120: 74 unresolved externals|
>> Note that before I switch from building GDAL from x32 to x64, I have to
>> rebuild *all* of the dependent libraries in x64 (this is the hardest
>> part of the whole process).
>> Also note to make sure that you run "nmake /f makefile.vc clean" before
>> each build.
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> *Mihaela Gaspar*
> *Urban Robotics Inc.**
> *Software Engineer
> 33 NW First Avenue, Suite 200 | Portland, OR 97209
> c: 971-269-9649
> http://www.urbanrobotics.net
*Mihaela Gaspar*
*Software Engineer
c: 971-269-9649
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130513/4d40d618/attachment.html>
