[gdal-dev] What is the difference between gdal.lib and gdal.i.lib ?
Frank Warmerdam
warmerdam at pobox.com
Tue May 14 11:08:38 PDT 2013
Mihaela,
gdal.i.lib is a stub library wrapping the GDAL DLL. Link against
gdal.i.lib if you want to use the DLL.
gdal.lib is a static library with everything in it. Link against this if
you want to avoid using the GDAL DLL.
Best regards,
Frank
On Tue, May 14, 2013 at 10:11 AM, Mihaela Gaspar <
mihaela.gaspar at urbanrobotics.net> wrote:
> The devinstall option copies gdal.i.lib into the target library
> installation folder.
> I see another lib file created, gdal.lib
> What is the difference between them ?
> I I link statically, do I use gdal.i.lib ?
> Thank you.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130514/1bfeb61b/attachment.html>
