[gdal-dev] Is it possible to build pdb files in Release ?
Mihaela Gaspar
mihaela.gaspar at urbanrobotics.net
Tue May 14 13:23:06 PDT 2013
Thank you, it's perfect.
On Tue, May 14, 2013 at 12:41 PM, David Strip <gdal at stripfamily.net> wrote:
> The pdb file is generated by the /Zi flag. Add that to the list of flags
> in your release build.
> On 5/14/2013 10:55 AM, Mihaela Gaspar wrote:
> I built GDAL in both Debug and Release.
> The default behavior is to create .pdb files in Debug, but not in
> Release.
> I would like to get a pdb file in Release build as well, is it possible ?
> The only lines I see that have to do with pdb, are:
> !IFNDEF DEBUG
> OPTFLAGS= $(CXX_ANALYZE_FLAGS) /nologo /MT /EHsc /Ox
> /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG
> /Fd$(LIBDIR)\gdal$(VERSION).pdb /ITERATOR_DEBUG_LEVEL=0
> !ELSE
> OPTFLAGS= $(CXX_ANALYZE_FLAGS) /nologo /MTd /EHsc /Zi
> /Fd$(LIBDIR)\gdal$(VERSION).pdb /DDEBUG /ITERATOR_DEBUG_LEVEL=2
> !ENDIF
> It is not apparent to me how to get pdb files to be created, based on
> this.
> Thank you.
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
*Mihaela Gaspar*
*Urban Robotics Inc.**
*Software Engineer
33 NW First Avenue, Suite 200 | Portland, OR 97209
c: 971-269-9649
http://www.urbanrobotics.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130514/9514f524/attachment.html>
