[gdal-dev] What is the best way to test if a CPLString is not empty?
Jorge Arévalo
jorgearevalo at libregis.org
Thu May 16 11:54:40 PDT 2013
That sounds perfect. Thanks Frank!
Jorge Arevalo
Freelance developer
http://www.krop.com/jorgearevalo
http://about.me/jorgeas80
Enviado con Sparrow (http://www.sparrowmailapp.com/?sig)
El jueves 16 de mayo de 2013 a las 20:07, Frank Warmerdam escribió:
> Jorge,
> I don't believe oString.c_str() will ever be NULL. You can use the std::string empty() method to test if a string is empty (zero length).
> http://www.cplusplus.com/reference/string/string/empty/
> CPLStrings have no equivelient to a NULL distinct from being a zero length string.
> Best regards,
> Frank
> On Thu, May 16, 2013 at 10:17 AM, Jorge Arévalo <jorgearevalo at libregis.org (mailto:jorgearevalo at libregis.org)> wrote:
> > If I define a CPLString this way:
> > CPLString osString;
> > And I want to check if osString is not empty, what would be the best way?
> > My bet:
> > if (osString.c_str() == NULL)
> > But I find it a little rusty... Is there any other better way?
> > Many thanks in advance
> > Jorge Arevalo
> > Freelance developer
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org (mailto:gdal-dev at lists.osgeo.org)
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com (mailto:warmerdam at pobox.com)
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
