[gdal-dev] Wrapping with SWIG
Tamas Szekeres
szekerest at gmail.com
Fri May 17 00:20:42 PDT 2013
Hank,
As far as I know Even Rouault has been working on the maintenance of
GDAL/Java wrapper in the recent time.
You may also consider using GDAL to access the spatialite db, which would
eliminate the need to create the wrapper around spatialite as you have
mentioned.
Best regards,
Tamas
2013/5/17 Hank Finley <assetfx at gmail.com>
> Hi All,
> I'm currently trying to create a wrapper for a C API with SWIG for use in
> Java. The API is for an open source spatial database called Spatialite.
> This is causing a few headaches and I need some help.
> My first question is did the SWIG wrappers for GDAL get created in-house
> or was it a paid for project?
> The second is there someone that could lend a hand?
> Regards Hank
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130517/e0eaa930/attachment.html>
