[gdal-dev] Problems when mixing https calls
Ari Jolma
ari.jolma at gmail.com
Tue May 21 03:27:27 PDT 2013
(sorry, gdal-dev was accidentally dropped)
On 05/21/2013 12:59 PM, Even Rouault wrote:
> Selon Ari Jolma <ari.jolma at gmail.com>:
>> On 05/21/2013 11:38 AM, Even Rouault wrote:
>>> Yes, that's the likely cause and using wfs as the namespace should fix it.
>>> Perhaps the detection of WFS documents could be made more robust, but in
>> the
>>> above case, I'm not sure that GML documents emitted by default by OGR are
>> valid
>>> WFS documents that could be successfully read by other WFS clients. I think
>> (but
>>> I'm not 100% positive about that) that the wfs namespace should appear
>>> somewhere. At least that's what I've seen in all documents emitted by WFS
>>> servers.
>> QGIS is happy with it. But ok, I can change the server also. That seems
>> to be settable now in OGR 1.10.
>> The GML did not parse into features until I changed the feature element
>> names to be the same that was advertised and had been recorded into a
>> GML Class - this is my bug clearly.
> You mean there was a mismatch between the schema returned by DescribeFeatureType
> and the content of GetFeature ?
Yes, the name of the feature was different.
>> However, before it was ok for GDAL
>> and it still is ok for QGIS. GDAL seems pickier now.
> This is perhaps due to the WFS/GML driver running in streaming mode now. It uses
> the schema to be able to decode the GetFeature XML on-the-fly. Previously it
> downloaded the whole file in memory and could analyze its structure without
> relying on the XML schema (although I believe that if the schema was available,
> it was used, so I'm not completely sure that's the explanation).
> You can probably revert to the old behaviour by setting the environmenent
> variable OGR_WFS_USE_STREAMING to NO.
ok, well, streaming is better anyway,
Ari
>> Thanks,
>> Ari
