[gdal-dev] GDAL 1.10 JP2000 Problem/Crash
Julien Malik julien.malik at c-s.fr
Thu May 23 06:34:26 PDT 2013
Hello Even,
On 05/22/2013 07:46 PM, Even Rouault wrote:
> Frank's above suggestions are the way to go. Tamas' builds do include MrSID
> support as a plugin (XXXX-mrsid.msi packages). But they also include the
> OpenJPEG driver, which can successfully open this file and should be the next
> driver used after skipping JP2ECW :
> $ gdalinfo --config GDAL_SKIP JP2ECW
> IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2
Does this mean that in an ideal "free software only" setup, OpenJPEG is
now the default driver (used before Jasper) ?
Thanks,
Julien
