[gdal-dev] Reading gml with schema
Ari Jolma
ari.jolma at gmail.com
Tue May 28 10:47:38 PDT 2013
On 05/28/2013 05:34 PM, Lauri Kajan wrote:
> Hi Ari,
> I think that shouldn't be neccessary.
> The gml file points to the xsd schema file
> (http://xml.nls.fi/XML/Schema/Maastotietojarjestelma/MTK/201202/Maastotiedot.xsd).
> In this schema those tags are defined to be "aliases" for these known
> gml tags by using the substitutionGroup. So actually that
> <Maastotiedot> is a <gml:FeatureCollection>. Is this supported by OGR?
I think GDAL wants the xsd to be local file for GML files. However, I
tried this and I can see GDAL finding the xsd, but failing the overall
process. Further, it seems that GDAL does not recognize the XML include tag.
Anyway, I assume it is not a simple substitution as all features should
be wrapped into gml:featureMember elements.
Ari
> I'm not an xml/gml expert either so it's hard to find the problem.
> -Lauri
> On Tue, May 28, 2013 at 5:11 PM, Ari Jolma <ari.jolma at gmail.com
> <mailto:ari.jolma at gmail.com>> wrote:
> Lauri,
> There are at least these issues with the file:
> - Piste should be gml:Point
> - Murtoviiva should be gml:LineString
> - Alue should be gml:Polygon
> - all features should be wrapped into gml:featureMember elements
> - everything should be in gml:FeatureCollection
> - complex geometries should be wrapped into gml:GeometryCollection
> elements
> With these changes and limitations I can open (a small piece) of
> the file with ogrinfo. All are probably changeable by XSLT. Of
> course my knowledge about GML and it's parsing in GDAL is limited,
> so take this with a grain of salt.
> Cheers,
> Ari
> the changed piece:
> <?xml version="1.0" encoding="UTF-8"?>
> <gml:FeatureCollection xmlns:gml="http://www.opengis.net/gml"
> <http://www.opengis.net/gml>>
> <harvatLouhikot>
> <gml:featureMember>
> <HarvaLouhikko gid="733051928" dimension="3">
> <sijaintitarkkuus>10000</sijaintitarkkuus>
> <korkeustarkkuus>100001</korkeustarkkuus>
> <aineistolahde>1</aineistolahde>
> <alkupvm>2005-11-15</alkupvm>
> <suunta>0</suunta>
> <sijainti>
> <gml:Point>
> <gml:pos srsDimension="3">368845.895
> 7588505.642 308.292</gml:pos>
> </gml:Point>
> </sijainti>
> <kohderyhma>13</kohderyhma>
> <kohdeluokka>34200</kohdeluokka>
> </HarvaLouhikko>
> </gml:featureMember>
> </harvatLouhikot>
> <hietikot>
> <gml:featureMember>
> <Hietikko gid="775477697" dimension="3">
> <sijaintitarkkuus>5000</sijaintitarkkuus>
> <sijainti>
> <gml:GeometryCollection>
> <gml:geometryMember>
> <gml:Point>
> <gml:pos srsDimension="3">368010.039
> 7584945.893 0.000</gml:pos>
> </gml:Point>
> </gml:geometryMember>
> <gml:Polygon>
> <gml:exterior>
> <gml:LinearRing>
> <gml:posList
> srsDimension="3">368000.000 7584931.821 370.229 368000.000
> 7584936.222 369.780 368001.115 7584941.126 368.906 368002.650
> 7584954.132 364.859 368002.478 7584969.653 361.051 368008.553
> 7584975.749 359.563 368016.839 7584970.791 359.517 368019.890
> 7584958.174 360.232 368023.171 7584944.026 362.917 368022.143
> 7584935.253 365.008 368016.168 7584924.893 368.340 368004.859
> 7584923.913 369.824 368000.000 7584931.821 370.229</gml:posList>
> </gml:LinearRing>
> </gml:exterior>
> </gml:Polygon>
> </gml:GeometryCollection>
> </sijainti>
> <kohderyhma>64</kohderyhma>
> <kohdeluokka>34300</kohdeluokka>
> </Hietikko>
> </hietikot>
> </gml:FeatureCollection>
> On 05/28/2013 02:06 PM, Lauri Kajan wrote:
>> Hello everybody,
>> I have tired to read gml file from National Land Suvey of Finnish
>> without a success.
>> Does anybody have any idea what's the problem?
>> The gml has a quite complex schema. Is this a problem for ogr?
>> I have tried to download all the schema files to the same folder
>> with the same name than the file but it doesn't work.
>> Here is a sample:
>> https://docs.google.com/file/d/0BwbdYcPHdb1pOEs1eGNiZnBhMUk/edit?usp=sharing
>> Thanks!
>> Lauri Kajan
>> Software Developer
>> Karttakeskus Ltd.
>> Atomitie 2
>> 00370 Helsinki
>> Finland
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130528/bff6a8e7/attachment.html>
