[gdal-dev] Unable to decode ADS100 images
Ledoux, Bruno
Bruno.Ledoux at astrium.eads.net
Mon Nov 4 03:13:41 PST 2013
Hi All,
I am trying to decode ADS100 raw images (.lov files) but gdal is failing with the following error message : "ERROR 1: Cannot open TIFF file due to missing codec."
The tiffdump utility from the TIFF library indicates that the Compression codec code is 65100 which is undefined by the TIFF specifications.
I am aware this is not an issue with GDAL but am wondering if someone has ever managed to open images compressed with the same codec.
Best Regards,
Bruno
PS : This question was initially posted on trac.osgeo.org but as suggested by Rouault the gdal-dev mailing list may have more traffic.
[cid:image60e3cf.JPG at b4f94a80.46a363fa] Please consider the environment before printing this email message.
Ce courriel (incluant ses éventuelles pièces jointes) peut contenir des informations confidentielles et/ou protégées ou dont la diffusion est restreinte. Si vous avez reçu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu à quiconque. Merci d'en avertir immédiatement l'expéditeur et d'effacer ce courriel de votre système. Spot Image décline toute responsabilité en cas de corruption par virus, d'altération ou de falsification de ce courriel lors de sa transmission par voie électronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Spot Image disclaims any and all liability if this email transmission was virus corrupted, altered or falsified.
Spot Image SA (325 089 589 RCS Toulouse) - Siege social: 5, rue des Satellites, 31400 Toulouse, France.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131104/a83f080a/attachment.html>
Type: image/jpeg
Desc: image60e3cf.JPG
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131104/a83f080a/attachment.jpe>
