[gdal-dev] [pdal] Building PDAL using pramsey-config.sh
Even Rouault even.rouault at mines-paris.org
Mon Nov 4 11:44:27 PST 2013
Le lundi 04 novembre 2013 20:30:08, Stefan Keller a écrit :
> Hi PDAL and GDAL list
> I'm referring to the error reported above when (still) trying to compile
> PDAL with pointcloud support.
> What I'm really wondering is why GDAL developpers are calling function
> gtCPLRealloc
> the same as in GeoTIFF lib but with different declaration?
> See
> /usr/include/gdal/cpl_port.h:533:89: => ‘void* gtCPLRealloc(void*, size_t)’
> and
> /usr/include/geotiff/cpl_serv.h:144:20 => ‘void* gtCPLRealloc(void*, int)’
> -S.
Not sure if the issue comes from GDAL. Looks a bit more like a bad interaction
between libgeotiff "simplified" CPL library (
http://trac.osgeo.org/geotiff/browser/trunk/libgeotiff/cpl_serv.h ) when mixed
with GDAL headers. Perhaps libgeotiff should be updated to use size_t instead
of int ?
If doable, the best thing would be for PDAL to avoid including in the same
.cpp file both geotiff/cpl_serv.h and gdal/cpl_port.h. Or cheating by #define
CPL_SERV_H_INCLUDED before including libgeotiff headers.
This reminds me of a similar discussion :
http://trac.osgeo.org/gdal/ticket/4374
Even
> 2013/10/29 Heng Zhi Feng (zheng at hsr.ch) <zheng at hsr.ch>
> >  Hello,
> > We are having issues building PDAL on Ubuntu 13.10, following the guide
> > on *[1].*
> > Initially, PDAL successfully compiles with using the “cmake –G “Unix
> > Makefiles” ../” command. However, when trying to import a sample .LAS
> > file into PostgreSQL 9.1 using the PDAL Pipeline application. The
> > following error occurred “Caught PDAL exception: Unable to create writer
> > for type ‘drivers.pgpointcloud.writer’.”.
> > Our next approach was to use the script “pramsey-config.sh” from github
> > and was thrown the following errors:
> > 1.       In file included from /usr/include/gdal/cpl_conv.h:34:0,
> >                  from
> > /home/zheng/Downloads/PDAL/src/drivers/las/GeotiffSupport.hpp:42,
> >                  from
> > /home/zheng/Downloads/PDAL/src/drivers/las/GeotiffSupport.cpp:35:
> > /usr/include/gdal/cpl_port.h:533:89: error: declaration of C function
> > ‘void* gtCPLRealloc(void*, size_t)’ conflicts with
> > #define CPL_WARN_UNUSED_RESULT
> > __attribute__((warn_unused_result))
> > /usr/include/gdal/cpl_conv.h:65:44: note: in expansion of macro
> > ‘_WARN_UNUSED_RESULT’
> > void CPL_DLL *CPLRealloc( void *, size_t ) CPL_WARN_UNUSED_RESULT;
> > 2.       In file included from
> > /usr/include/geotiff/geo_simpletags.h:34:0,
> >                  from
> > /home/zheng/Downloads/PDAL/src/drivers/las/GeotiffSupport.hpp:41,
> >                  from
> > /usr/include/geotiff/cpl_serv.h:144:20: error: previous declaration
> > ‘void* gtCPLRealloc(void*, int)’ here
> > #define CPLRealloc gtCPLRealloc
> > ** We had adapted the path for the dependencies to our system in the
> > script.
> > Would greatly appreciate if someone could advise on how to proceed.
> > Thank you.
> > Regards,
> > Zhi Feng
> > *[1]* http://www.pointcloud.org/compilation/unix.html
> > pdal mailing list
> > pdal at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/pdal
Geospatial professional services
http://even.rouault.free.fr/services.html
