[gdal-dev] Writing GPX Files with multiple Extensions
Pouliot, Christopher (MNIT)
Christopher.Pouliot at state.mn.us
Thu Nov 7 12:15:04 PST 2013
Attached is a sample from downloading one Waypoint and a track using GPSBabel. I'll look into the GPSBabel driver. I don't have much time to devote to this so hope to find a relatively quick solution.
Thanks again!
Chris
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Thursday, November 07, 2013 1:47 PM
To: Pouliot, Christopher (MNIT)
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Writing GPX Files with multiple Extensions
Le jeudi 07 novembre 2013 20:41:48, Pouliot, Christopher (MNIT) a écrit :
> Even,
> Thanks for the response! I see that GPSBabel uses GDAL
Really ? OGR has a GPSBabel driver, but I didn't know that the reversed way existed.
> and writes out
> multiple extensions. I'll check with them to see how they are doing it.
GPSBabel has its own GPX reader/writer. It wouldn't be difficult to extend the OGR GPX driver to implement what I mentionned below. Alternatively you could generate the GPX yourself. It is quite easy.
> Chris
> Sent: Thursday, November 07, 2013 1:22 PM
> To: gdal-dev at lists.osgeo.org
> Cc: Pouliot, Christopher (MNIT)
> Le jeudi 07 novembre 2013 16:51:35, Pouliot, Christopher (MNIT) a écrit :
> > Hello All,
> > I am currently using GDAL 1.9 and I'm writing out GPX files for
> > uploading onto Garmin units. Garmin has many different GPX
> > extensions (gpxx, gpxtpx, gpxtrx, etc) for defining extra attributes
> > for their GPS data. I am wondering how I would specify these
> > multiple extensions in my code? Currently, I am defining a single extension as shown below:
> > ds = drv.CreateDataSource(outputFilePath, new string[] {
> > "GPX_USE_EXTENSIONS=YES","GPX_EXTENSIONS_NS=gpxx","GPX_EXTENSIONS_NS
> > _U RL=h ttp://www.garmin.com/xmlschemas/GpxExtensions/v3"});}
> > How would I go about setting more namespaces (gpxtpx, gpxtrx, ...)?
> This is not possible currently. Would require an enhancement in the
> driver, like acception a comma separated list of values for
> GPX_EXTENSIONS_NS and GPX_EXTENSIONS_NS_URL
> > And
> > then how would I specify that an attribute belongs in a particular
> > extension?
> It could detect it by the name of attribute. For example, gpxx_foo,
> gpxtpx_bar, gpxtrx_baz
> > Thanks,
> > Chris
> > Chris Pouliot | GIS Application Developer MN.IT Services @
> > Department of Natural Resources
> > (651) 259-5491 (w) | christopher.pouliot at state.mn.us
> > [cid:image002.jpg at 01CEDB9E.F20C9670]<http://www.mn.gov/oet> Information
> > Technology for Minnesota Government |
> > mn.gov/oet<http://www.mn.gov/oet>
> Geospatial professional services
> http://even.rouault.free.fr/services.html
Type: application/octet-stream
Desc: babel.gpx
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131107/dbf9648b/attachment.obj>
