[gdal-dev] libpng and autotest
Even Rouault
even.rouault at mines-paris.org
Fri Nov 8 11:24:51 PST 2013
Le vendredi 08 novembre 2013 18:50:45, Jack Howarth a écrit :
> On Fri, Nov 08, 2013 at 09:12:05AM -0800, Kurt Schwehr wrote:
> > Jack,
> > Is there an explanation someplace with more detail as to what is wrong
> > those png's, why older versions of libpng are okay with it and why
> > libpng has changed its behavior?
> > Thanks,
> > -kurt
> Kurt,
> The following link...
> http://comments.gmane.org/gmane.comp.graphics.png.devel/6017
> appears to discuss the issue we are seeing with the test.png file...
> > Libpng-1.6.0 through 1.6.2 use the CMF bytes at the beginning of an zlib
> > datastream to set the window size for decoding. Libpng-1.5.x and
> > earlier ignored the CMF bytes and always used a 32kbyte window.
> > Libpng-1.6.x has uncovered the fact that there are hundreds of files in
> > the wild (found in linux distributions such as gentoo) with a too-small
> > CMF, which results in a "Too far back" error when decoding these PNGs.
> > I have not yet been able to discover what application is producing
> > these.
> If you read completely through the gmane.comp.graphics.png.devel/6017
> thread, you should be at least convinced that such corruption is a known
> issue.
This is strange. I can't reproduce any issue on Linux with libpng 1.6.2 or
libpng 1.6.3 with gdalicon.png or autotest/gdrivers/data/test.png that is used
by png_1 test. If it matters, the zlib is still my system zlib 1.2.3.
$ ldd apps/gdalinfo | grep png
libpng16.so.16 => /home/even/install-libpng-1.6.2/lib/libpng16.so.16
(0x00007fda95e39000)
$ gdalinfo data/gdalicon.png -checksum
Driver: PNG/Portable Network Graphics
Files: data/gdalicon.png
Size is 32, 32
Coordinate System is `'
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 32.0)
Upper Right ( 32.0, 0.0)
Lower Right ( 32.0, 32.0)
Center ( 16.0, 16.0)
Band 1 Block=32x1 Type=Byte, ColorInterp=Red
Checksum=7617
Mask Flags: PER_DATASET ALPHA
Band 2 Block=32x1 Type=Byte, ColorInterp=Green
Checksum=7808
Band 3 Block=32x1 Type=Byte, ColorInterp=Blue
Checksum=7377
Band 4 Block=32x1 Type=Byte, ColorInterp=Alpha
Checksum=7926
$ gdalinfo ../autotest/gdrivers/data/test.png -checksum
Files: ../autotest/gdrivers/data/test.png
../autotest/gdrivers/data/test.wld
Size is 400, 400
GeoTransform =
700000.3050000001, 0.38, 0.01
4287500.695, -0.01, -0.38
Corner Coordinates:
Upper Left ( 700000.305, 4287500.695)
Lower Left ( 700004.305, 4287348.695)
Upper Right ( 700152.305, 4287496.695)
Lower Right ( 700156.305, 4287344.695)
Center ( 700078.305, 4287422.695)
Band 1 Block=400x1 Type=Byte, ColorInterp=Palette
Checksum=57921
NoData Value=0
Color Table (RGB with 16 entries)
0: 255,255,255,0
1: 255,255,208,255
2: 255,255,204,255
3: 153,204,255,255
4: 0,153,255,255
5: 102,102,102,255
6: 153,153,153,255
7: 150,150,150,255
8: 0,0,0,255
9: 100,160,210,255
10: 255,255,255,255
11: 226,226,226,255
12: 51,51,51,255
13: 0,0,0,255
14: 0,0,0,255
15: 0,0,0,255
> Jack
> > On Nov 8, 2013, at 8:02 AM, Jack Howarth <howarth at bromo.med.uc.edu> wrote:
> > > On Fri, Nov 08, 2013 at 10:31:08AM -0500, Jack Howarth wrote:
> > >> On Thu, Nov 07, 2013 at 04:34:07PM -0500, Jack Howarth wrote:
> > >>> The failures on x86_64-apple-darwin13 for the png.py test suite from
> > >>> auto test for gdal 0.10.1 are the same failures described here...
> > >>> https://github.com/licq-im/licq/pull/32
> > >>> <https://github.com/licq-im/licq/pull/32>
> > >>> The failures are completely suppressed by regenerating
> > >>> autotest/gdrivers/data/test.png with
> > >>> "optipng -nb -nc -np test.png"...
> > >> Just to clarify, I used optipng 0.6.3 for this. The newer optipng
> > >> 0.7.4 release seems more problematic as none of the obvious
> > >> combination of options can fix the test.png file without changing the
> > >> checksums and causing additional failures. So you will want to use
> > >> the optipng 0.6.x release series to fix the bad png files in gdal.
> > > Also, my tests here using optipng 0.7.4 to detect damaged png files
> > > indicate that only data/gdalicon.png in gdal-0.10.1 needs to be fixed.
> > > optipng -nb -nc -np -fix data/gdalicon.png
> > > ** Processing: data/gdalicon.png
> > > Warning:
> > > 32x32 pixels, 4x8 bits/pixel, RGB+alpha
> > > Recoverable errors found in input. Fixing...
> > > Input IDAT size = 1964 bytes
> > > Input file size = 2021 bytes
> > > Trying:
> > > zc = 9 zm = 8 zs = 0 f = 0 IDAT size = 240
> > > Selecting parameters:
> > > Output IDAT size = 240 bytes (1724 bytes decrease)
> > > Output file size = 313 bytes (1708 bytes = 84.51% decrease)
> > > ** Status report
> > > 1 file(s) have been processed.
> > > 1 error(s) have been encountered.
> > > 1 erroneous file(s) have been fixed.
> > >>> % ./png.py
> > >>> TEST: png_1 ... success
> > >>> TEST: png_2 ... success
> > >>> TEST: png_3 ... success
> > >>> TEST: png_4 ... success
> > >>> TEST: png_5 ... success
> > >>> TEST: png_6 ... success
> > >>> TEST: png_7 ... success
> > >>> TEST: png_8 ... success
> > >>> TEST: png_9 ... success
> > >>> TEST: png_10 ... success
> > >>> TEST: png_11 ... success
> > >>> Test Script: png
> > >>> Succeeded: 11
> > >>> Failed: 0 (0 blew exceptions)
> > >>> Skipped: 0
> > >>> Expected fail:0
> > >>> Duration: 0.08s
> > >>> _______________________________________________
> > >>> gdal-dev mailing list
> > >>> gdal-dev at lists.osgeo.org
> > >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Geospatial professional services
http://even.rouault.free.fr/services.html
