[gdal-dev] Getting SRID from MS SQL Server Spatial Table
Tamas Szekeres szekerest at gmail.com
Wed Nov 13 13:25:24 PST 2013
Bob,
You should specify the SRID as the attribute in the geometries in the
database table, which should also set the spatial reference of the layer.
Best regards,
Tamas
2013/11/13 Bob Cave <bobc at bluemarblegeo.com>
> Hello,
> I am using the MS SQL Server driver (1.10.1) with
> MSSQLSPATIAL_USE_GEOMETRY_COLUMNS=NO.  When I attempt to read a table, I
> find that the driver does not identify the spatial reference the table is
> using.  Is there a way to get the driver to query for the SRID?
> When I use MSSQLSPATIAL_USE_GEOMETRY_COLUMNS=YES, then the SRID can be
> identified.  This is fine for my test database, but I need to be able to
> support databases that don't have a geometry_columns table.
> Thanks,
> Bob
> http://osgeo-org.1560.x6.nabble.com/Getting-SRID-from-MS-SQL-Server-Spatial-Table-tp5089019.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131113/ef21a94e/attachment.html>
