[gdal-dev] Getting SRID from MS SQL Server Spatial Table
Bob Cave bobc at bluemarblegeo.com
Thu Nov 14 08:51:56 PST 2013
Hi Tamas,
I looked through the source code for the MS SQL Server Spatial driver,
version 1.10.1 and in the latest trunk download, and was unable to find that
query.  Is that something that you have added but not checked in yet?
In any case, I will give try that query myself.  Thanks.
Cheers,
Bob
Tamas Szekeres wrote
> The driver is doing something like:
> select top 1 ogr_geometry.STSrid from [mytable]
> Best regards,
> Tamas
> 2013/11/13 Bob Cave <
> bobc@
>> Tamas,
>> Thank you for the quick reply.
>> My code is reading a table, so I am trying to identify the SRID that was
>> used when the table was created and the geometries were added to the
>> table.
>> How do I query the SRID from the geometry in the table?  The MS SQL
>> Server
>> driver does this when it is reading the geometry_columns table, but when
>> the
>> driver is not using the geometry_columns table, it does not attempt to
>> identify the SRID. I am trying to determine how I can do this myself.
>> Thanks,
>> Bob
>> > Bob,
>> > You should specify the SRID as the attribute in the geometries in the
>> > database table, which should also set the spatial reference of the
>> layer.
>> > Best regards,
>> > Tamas
>> > bobc@
>> >> Hello,
>> >> I am using the MS SQL Server driver (1.10.1) with
>> >> MSSQLSPATIAL_USE_GEOMETRY_COLUMNS=NO.  When I attempt to read a table,
>> I
>> >> find that the driver does not identify the spatial reference the table
>> is
>> >> using.  Is there a way to get the driver to query for the SRID?
>> >> When I use MSSQLSPATIAL_USE_GEOMETRY_COLUMNS=YES, then the SRID can be
>> >> identified.  This is fine for my test database, but I need to be able
>> to
>> >> support databases that don't have a geometry_columns table.
>> >> Thanks,
>> >> Bob
>> >> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Getting-SRID-from-MS-SQL-Server-Spatial-Table-tp5089019.html
>> >> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> gdal-dev mailing list
>> > gdal-dev at .osgeo
>> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> > gdal-dev at .osgeo
>> http://osgeo-org.1560.x6.nabble.com/Getting-SRID-from-MS-SQL-Server-Spatial-Table-tp5089019p5089033.html
> gdal-dev at .osgeo
> gdal-dev at .osgeo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Getting-SRID-from-MS-SQL-Server-Spatial-Table-tp5089019p5089183.html
