[gdal-dev] Support USRP
xavier lhomme lhomme.xavier at gmail.com
Mon Nov 18 04:45:32 PST 2013
Hi
 I've submitted a ticket #5297 and attached a new version of the usrp/asrp
driver.
Best Regards
2013/11/18 Even Rouault <even.rouault at mines-paris.org>
> Selon xavier lhomme <lhomme.xavier at gmail.com>:
> > Hi
> >   What should be the return of gdalinfo after reading a TRANSH01.THF :
> >    I have added all IMG in subdatasets. But should I set a
> SpatialReference
> > and Extent for the main dataset (by merging all Extent in one ) ?
> Datasets that only report subdatasets generally don't define any spatial
> reference or extent. Basically they keep with the defaults of the
> GDALDataset
> constructor.
> > xav
> > 2013/11/15 Even Rouault <even.rouault at mines-paris.org>
> > > Le jeudi 14 novembre 2013 10:35:35, xavier lhomme a écrit :
> > > > Hi
> > > >   I have a USRP product with several images organized with
> > > >    a THF file which describe all containing image and a directory for
> > > each
> > > > image
> > > > (with  .Gen, .SOU, .IMG and a .QAL ).
> > > > The ASRP/USRP driver recognize .IMG file as explain in the web site.
> > > > ASRP/USRP is related to ADRG (and source code is stored in the ADRG
> > > > directory)
> > > > the ADRG driver is able to recognize THF file
> > > > Is it possible to improve ASRP/USRP driver to support THF files ?
> > > That is undoubtedly technically doable. The THF being a catalog, the
> best
> > > use
> > > of it I can see in an enhanced driver would be to report those images
> as
> > > SUBDATASETS of the THF dataset.
> > > > Best regards
> > > > xlhomme
> > > Geospatial professional services
> > > http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131118/977787bd/attachment.html>
