[gdal-dev] ogr2og / forcing a +-180 system
Robb K. Wright
robbkwright at gmail.com
Mon Nov 18 08:36:54 PST 2013
I need to use ogr2ogr (or any other command line) to convert a shapefile
with longitudes spanning from -220 to -60, forcing it into a +-180
scheme, so the -220 coordinate would come out as +140 and the -60 stays
as -60. I don't need to worry about the polys that actually cross the
180 line.
Any thoughts? I was thinking that running it through EPSG:4326 would
reshape it (as it does in Esri-land), but no luck.
Robb
