[gdal-dev] How to implement tile read / write to gdal supported format file?
Luke
lukepinnerau at gmail.com
Mon Nov 18 23:34:16 PST 2013
You could do something like the following:
(code modified from the gdal_calculations library -
http://code.google.com/p/gdal-calculations)
from osgeo import gdal
class Block(object):
def __init__(self, dataset, band, xoff, yoff, xsize, ysize):
self.xoff = xoff
self.yoff = yoff
self.xsize = xsize
self.ysize = ysize
if not band: self.data = dataset.ReadAsArray(xoff, yoff, xsize,
ysize)
else: self.data = dataset.GetRasterBand(band).ReadAsArray(xoff,
yoff, xsize, ysize)
def read_blocks_as_array(dataset, band=0, nblocks=1):
'''Read GDAL Datasets or individual Bands block by block'''
ncols=dataset.RasterXSize()
nrows=dataset.RasterYSize()
xblock,yblock=dataset.GetRasterBand(1).GetBlockSize()
if xblock==ncols:
yblock*=nblocks
else:
xblock*=nblocks
for yoff in xrange(0, nrows, yblock):
if yoff + yblock < nrows:
ysize = yblock
else:
ysize = nrows - yoff
for xoff in xrange(0, ncols, xblock):
if xoff + xblock < ncols:
xsize = xblock
else:
xsize = ncols - xoff
yield Block(dataset, band, xoff, yoff, xsize, ysize)
ds1=gdal.Open(some_raster)
ds2=gdal.Open(another_raster)
out_driver=gdal.GetDriverByName('GTIFF')
out_ds=out_driver.Create (out_raster,ds1.RasterXSize(),ds1.RasterYSize(),
1,ds1.GetRasterBand(1).DataType,
['BIGTIFF=IF_SAFER'])
out_ds.SetGeoTransform(ds1.GetGeoTransform())
out_ds.SetProjection(ds1.GetProjection())
out_band=out_ds.GetRasterBand(1)
for block in read_blocks_as_array(ds1,band=1,nblocks=10):
block2=Block(ds2, 1, block.xoff, block.yoff, block.xsize, block.ysize)
ndarray1=block.data
ndarray2=block2.data
result = ndarray1+ndarray2
out_band.WriteArray(result, block.xoff, block.yoff)
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-How-to-implement-tile-read-write-to-gdal-supported-format-file-tp5089581p5089803.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
