[gdal-dev] ECW lossless JPEG 2000 compression issue
Jeremy Palmer
JPalmer at linz.govt.nz
Sat Nov 23 14:04:55 PST 2013
Thanks Jukka.
________________________________________
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jukka Rahkonen [jukka.rahkonen at mmmtike.fi]
Sent: Sunday, 24 November 2013 9:48 a.m.
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] ECW lossless JPEG 2000 compression issue
Jeremy Palmer <JPalmer <at> linz.govt.nz> writes:
> Has anyone else had issues when reading lossless JPEG 2000 files in the
3.3 SDK? Have I got all of the patches applied?
You are out of luck with 3.x SDK. You need SDK 4.2 or above, see
http://trac.osgeo.org/gdal/ticket/2805
-Jukka Rahkonen-
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
