[gdal-dev] reading hdf4 files in R
Etienne Tourigny
etourigny.dev at gmail.com
Mon Nov 25 10:25:18 PST 2013
fwtool is really old so you should not use it and uninstall it.
You may want to use the R package Rgdal, but I have not used iit under
windows.
http://cran.r-project.org/web/packages/rgdal/index.html
On Mon, Nov 25, 2013 at 6:16 AM, Lucia Rueda Ramirez
<lucia.rueda at ba.ieo.es>wrote:
> Hi,
> I am trying to read hdf4 files in R. I have tried to install the gdal
> package from http://trac.osgeo.org/gdal/wiki/DownloadSource but I get an
> error message saying that the description file is missing (Error: Does not
> appear to be an R package (no DESCRIPTION)).
> I have also tried to load the hdf4 files using the modis library and the
> code
> sds <- getSds("C:/mypath/T20011612001168.L3m_8D_CHL_chlor_a_4km.hdf")
> But I get the following errors:
> 'FWTools/OSGeo4W' installation not found or path not set.
> If you don't have installed one of them you can get it from '
> http://fwtools.maptools.org/' or 'http://trac.osgeo.org/osgeo4w/'
> (recommanded)
> Trying to autodetect path to 'FWTools/OSGeo4W' (this may takes some time,
> you can interupt this process and set it manually, see 'gdalPath' argument
> in '?MODISoptions':
> Found 'FWTools' version: '1.7.0b2' to enalbe this run:
> MODISoptions(gdalPath='c:/Archivos de programa/FWTools2.4.7/bin') Found
> 'OSgeo4W' version: '1:' in 'c:/OSGeo4W/bin' but without HDF4
> support...strange, try to remove and re-install 'OSgeo4W'!
> Error in getSds("C:/Documents and Settings/lucia.rueda/Mis
> documentos/MEDITS/tema_clorofila/T20011612001168.L3m_8D_CHL_chlor_a_4km.hdf")
> Method GDAL does not work. Is GDAL installed properly on your system?
> Run:
> 'checkTools()' to check out which metods should work on your system!
> I have already installed the FWTools/OSGeo4W from the recommended url
> above though I got installation errors as well...
> Anyone with the same problem?? Any help would be apreciated. I have gone
> through most forums but can't figure out how to solve this.
> Thanks a lot
> Lucia
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131125/1ff2cfac/attachment.html>
