[gdal-dev] Large shapefile issues
Even Rouault even.rouault at mines-paris.org
Mon Nov 25 14:52:44 PST 2013
Le lundi 25 novembre 2013 11:42:23, CARMAN, Darren a écrit :
> Hi List
> I notice on the OGR formats page for ESRI Shapefile the following is
> mentioned:
> Size Issues
> Geometry: The Shapefile format explicitly uses 32bit offsets and so
> cannot go over 8GB (it actually uses 32bit offsets to 16bit words).
> Hence, it is is not recommended to use a file size over 4GB.
> Attributes: The dbf format does not have any offsets in it, so it can be
> arbitrarily large.
> Yet on the ESRI website:
> Geometry limitations
> There is a 2 GB size limit for any shapefile component file, which
> translates to a maximum of roughly 70 million point features. The actual
> number of line or polygon features you can store in a shapefile depends
> on the number of vertices in each line or polygon (a vertex is
> equivalent to a point).
> I assume the OGR web page is wrong, or has a different meaning outside
> of ESRI S/W use.
Darren,
Yes, as underlined by Chaitanya the actual limit depends on the software
implementation. Actually the limit in OGR was 4 GB for the .SHP, and AFAICS
unlimited for DBF.
I've added in http://trac.osgeo.org/gdal/changeset/26657 a 2GB_LIMIT=YES layer
creation option (and SHAPE_2GB_LIMIT configuration option) that will enforce
the 2GB limit. And in http://trac.osgeo.org/gdal/changeset/26658 a change so
that when the layer is reached the file is properly closed with the valid
information.
Spliting files over several files would properly need to be done outside of
this, in a script, by restarting from the source layer at the index next to
the one that was last written in the shapefile.
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
