[gdal-dev] cannot read grib1 file, expect PV=255
zvanaz giovanni.leoncini at aspen-re.com
Wed Nov 27 02:50:35 PST 2013
Hello,
when I try to read a specific grib1 file with readGDAL I get this error:
Error in .local(.Object, ...) :
>>  file.grb is a grib file, but no raster dataset was successfully
>> identified.
digging a bit further (Roger, thanks for this!):
gdalinfo --debug on file.grb
I see:
Warning: Inside GRIB2Inventory, Message # 50
ERROR: Couldn't find 'GRIB' or 'TDLP'
There were 6 trailing bytes in the file.
Un-handled possible ensemble section center 78 subcenter 255
GRIB: Problems with ReadGrib1Record called by ReadGrib2Record Inside
ReadGrib1Record
GRIB1 GDS: Expect PV = 255 != 43
is there any update on this? or maybe a workaround? sounds like this error
is not uncommon.
any help or hint would be appreciated!
thanks in advance
Giovanni
View this message in context: http://osgeo-org.1560.x6.nabble.com/cannot-read-grib1-file-expect-PV-255-tp5091447.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
