[gdal-dev] [EXTERNAL] Minimum user rights needed for Oracle driver
Smith, Michael ERDC-RDE-CRREL-NH Michael.Smith at erdc.dren.mil
Tue Oct 1 13:58:14 PDT 2013
Jukka,
Basically, you need read access to the schema.table in question. The
spatial views are automatically available if a user has read access to the
table. So the minimum access is
GRANT SELECT on SCHEMA.TABLENAME to USERNAME;
ALL_SDO_GEOM_METADATA is a view that contains metadata information for all
spatial tables on which the user has SELECT permission. It is this view
that OGR uses to access Oracle Spatial data.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
On 10/1/13 4:42 PM, "Jukka Rahkonen" <jukka.rahkonen at mmmtike.fi> wrote:
>Hi,
>PostGIS manual page has a useful chapter about what rights GDAL user needs
>" You must have permissions on all tables you want to read and
>geometry_columns and spatial_ref_sys.
>Misleading behavior may follow without an error message if you do not have
>permissions to these tables. Permission issues on geometry_columns and/or
>spatial_ref_sys tables can be generally confirmed if you can see the
>tables
>by setting the configuration option PG_LIST_ALL_TABLES to YES. (e.g.
>ogrinfo
>--config PG_LIST_ALL_TABLES YES PG:xxxxx) "
>Oracle Spatial manual page http://www.gdal.org/ogr/drv_oci.html is missing
>this information. I have also a feeling that with Oracle there are more
>tables and views and Oracle system stuff involved. Is here anybody who
>could
>tell what rights GDAL user must have for a) read access b) read and write
>access? It would be ideal to have a comprehensive list that could be given
>for the ever friendly DB admins
>GRANT [privileges] ON [object_1] TO [user]
>GRANT [privileges] ON [object_2] TO [user]
>-Jukka Rahkonen-
>_______________________________________________
>gdal-dev mailing list
>gdal-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
