[gdal-dev] [EXTERNAL] Minimum user rights needed for Oracle driver
Rahkonen Jukka jukka.rahkonen at mmmtike.fi
Tue Oct 1 14:28:11 PDT 2013
What about if GDAL and Oracle can't find common understandment about SRID? I have seen that GDAL tries then  to insert something into MDSYS.CS_SRS and with our user rights that fails always. I have not studied that further because that comes always from my error and adding -lco SRID helps which is lucky because our db admins tend to be jealous about the MDSYS area.
Nothing to worry about USER/ALL_SDO_INDEX_METADATA, is it handled automatically together with read/write rights to tables and views?
-Jukka-
________________________________________
Smith, Michael wrote:
> For write access, one needs INSERT and/or UPDATE on an existing table. For
> a new table, a user needs CREATE TABLE and CREATE SEQUENCE access to a
> Schema and some tablespace allocation for the schema, ALTER USER USERNAME
> QUOTA <SIZE> on TABLESPACE Y,   or GRANT UNLIMITED TABLESPACE to USERNAME.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
On 10/1/13 4:58 PM, "Smith, Michael ERDC-RDE-CRREL-NH"
<Michael.Smith at erdc.dren.mil> wrote:
>Jukka,
>Basically, you need read access to the schema.table in question. The
>spatial views are automatically available if a user has read access to the
>table. So the minimum access is
>GRANT SELECT on SCHEMA.TABLENAME to USERNAME;
>ALL_SDO_GEOM_METADATA is a view that contains metadata information for all
>spatial tables on which the user has SELECT permission. It is this view
>that OGR uses to access Oracle Spatial data.
>Mike
>Michael Smith
>US Army Corps
>On 10/1/13 4:42 PM, "Jukka Rahkonen" <jukka.rahkonen at mmmtike.fi> wrote:
>>Hi,
>>PostGIS manual page has a useful chapter about what rights GDAL user
>>needs
>>" You must have permissions on all tables you want to read and
>>geometry_columns and spatial_ref_sys.
>>Misleading behavior may follow without an error message if you do not
>>have
>>permissions to these tables. Permission issues on geometry_columns and/or
>>spatial_ref_sys tables can be generally confirmed if you can see the
>>tables
>>by setting the configuration option PG_LIST_ALL_TABLES to YES. (e.g.
>>ogrinfo
>>--config PG_LIST_ALL_TABLES YES PG:xxxxx) "
>>Oracle Spatial manual page http://www.gdal.org/ogr/drv_oci.html is
>>missing
>>this information. I have also a feeling that with Oracle there are more
>>tables and views and Oracle system stuff involved. Is here anybody who
>>could
>>tell what rights GDAL user must have for a) read access b) read and write
>>access? It would be ideal to have a comprehensive list that could be
>>given
>>for the ever friendly DB admins
>>GRANT [privileges] ON [object_1] TO [user]
>>GRANT [privileges] ON [object_2] TO [user]
>>-Jukka Rahkonen-
>>_______________________________________________
>>gdal-dev mailing list
>>gdal-dev at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/gdal-dev
