[gdal-dev] Compile GDAL with GEOS, strange GEOS_CFLAGS
Even Rouault even.rouault at mines-paris.org
Fri Oct 4 14:08:35 PDT 2013
Le vendredi 04 octobre 2013 10:21:13, Paul Meems a écrit :
> Hi all,
> As mentioned before I'm trying to upgrade all supporting libraries we are
> using with MapWinGIS.
> I'm also documenting all steps so others can do this as well.
> The build seems to be OK but I'm wondering about this part:
> GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/source/headers -DHAVE_GEOS
> I have no $(GEOS_DIR)/source folder. I'm using GEOS v3.4.2.
> I noticed in the past we used the same flags and the folder didn't exists
> either, so most likely it is nothing to worry about ;)
> But I want to make sure. Should I change it, delete it or leave it?
If that compiles, no reason to worry. The suggested flags in the nmake.opt just
reflect the directory organization of a (now) ancient GEOS version.
> I'm running Win7 and compile using nmake in a VS2008 command prompt.
> Thanks,
> Paul
>  *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
Geospatial professional services
http://even.rouault.free.fr/services.html
