[gdal-dev] GDAL and GeoPDF with Poppler (Couple issues)
Robert Zermeno
refriguy68 at yahoo.com
Tue Oct 8 10:09:05 PDT 2013
Thanks Even,
>One thing to remind is that some layers are turned off by default in PDF. So
>defining GDAL_PDF_LAYERS_OFF "Grids" will turn off "grids", but will let layers
>that defaulted to OFF as OFF. So if you want all layers but "Grids", you need
>to specify --config GDAL_PDF_LAYERS "ALL" as well. When both are defined,
>GDAL_PDF_LAYERS_OFF will override GDAL_PDF_LAYERS.
That logic makes sense to me...I will have to say as I integrated to the newer version of Poppler I noticed that for the command:
> $ gdal_translate.exe c:\world.pdf out.tif --config GDAL_PDF_LAYERS "ALL" --config GDAL_PDF_LAYERS_OFF "Grids"
I had success generating the proper image for Poppler v0.24.2 (latest release), but when I used "KDE for Windows" poppler build v0.22.3 I am not able to reproduce the same output. Rather, many layers were missing. Nothing was changed to the PDF file used on both execution.
Has anyone else experienced this issue? I would like to assist in verifying functionality of this feature. What can I do to help out?
Robert
From: Even Rouault <even.rouault at mines-paris.org>
To: gdal-dev at lists.osgeo.org; Robert Zermeno <refriguy68 at yahoo.com>
Sent: Monday, October 7, 2013 3:50 PM
Subject: Re: [gdal-dev] GDAL and GeoPDF with Poppler (Couple issues)
Le mardi 08 octobre 2013 00:26:45, Robert Zermeno a écrit :
> Ladies/Gents,
> I have been using GeoPDF capability with 0.16.3 for a while and enjoy the
> capabilities GDAL provides. I have wanted to add the capability to turn
> Layers On/Off using the features provided. Lets assume I have a file
> called world.pdf that contains more than 5 Layers with sub-layers.
> Project Configuration:
> GDAL_repos: 9-28-2013
> Poppler: version 0.16.3
> OS: Windows XP SP3
> Build: MSVC 2008
> Once built with the configuration above, I used the technique provided in
> the frmt_pdf.html page using gdal_translate.exe to turn off 1 Layer:
> $ gdal_translate.exe c:\world.pdf out.tif --config GDAL_PDF_LAYERS_OFF
> "Grids"
> I assume I used the proper request to only turn off "Grids" and allow all
> other LAYERS "On". The problem I get is when it executes more layers are
> turned "off" than the single layer specified.
> Here are my issues:
> 1. How do I request to output a file that turns off one or more Layers and
> keeps the others on?
> 2. According to the frmt_pdf.html, under the Configuration Options,
> GDAL_PDF_LAYERS and GDAL_PDF_LAYERS_OFF both state "When this option is
> specified, layers not explicitly listed will be turned off".
> I hope a quick copy & paste was performed...
Yes copy & paste error. The comment "When this option is specified, layers not
explicitly listed will be turned off" only applies to GDAL_PDF_LAYERS
> 3. When I executed gdal_translate.exefrom the request above, I got the
> following Error:
> ERROR 1: Could not find a OCG with Ref (13:0)
> ERROR 1: Could not find a OCG with Ref (30:0)
> ...repeats with different Ref() numbers
> ERROR 1: Could not find a OCG with Ref (153:0)
> This is a known Poppler issue as you can see here:
> https://bugs.freedesktop.org/show_bug.cgi?id=39637
> It states that the fix was added to Poppler version 0.17.2 >=
> If that is true, the documentation (frmt_pdf.html) should indicate that. I
> do not know if that is why my generated file is not correct as I do not
> know what is effect by this recoverable error mentioned above.
This is likely but impossible to be sure without verifying.
> I have not added a ticket for GDAL before, where is the location I can add
> future bugs if they arise?
http://trac.osgeo.org/gdal/newticket
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131008/f99ed74d/attachment.html>
