[gdal-dev] Create a vrt accounting for multiple raster bands
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Oct 9 04:16:13 PDT 2013
fargalaxy1 <magi.forums <at> gmail.com> writes:
> How can I modify the /gdal_translate -of VRT/ [...]  command line to add in
> the vrt a VRTRasterBand block for each band?
Works for me with GDAL 1.10 on Windows.
Are you sure that your input file is RGB and not for for example with a
palette? What do you see if you do
gdalinfo input_rgb.tif
-Jukka Rahkonen-
