[gdal-dev] Buffer unit
Iván Sánchez Ortega ivan at sanchezortega.es
Thu Oct 10 04:06:42 PDT 2013
El Jueves, 10 de octubre de 2013 13:16:42 Jaak Laineste escribió:
> Isn't there really better solution than dual-transformation? [...] Good
> solution would be to implement buffer function from latitude/longitude
> directly, say buffer(lat,lon,buffer_meters).  Any takers?
Actually, what you want is a buffer(lat, lon, degrees) algorithm that works on
polar coordinates on a topological sphere/geoid (as opposed to cartesian
coords on a plane).
But if PostGIS geography hasn't implemented that, my bet is that no one has.
Yet.
Best,
Iván Sánchez Ortega <ivan at sanchezortega.es>
