[gdal-dev] OGRLayer.Intersection() question
Tamas Szekeres szekerest at gmail.com
Thu Oct 10 13:21:44 PDT 2013
Dheeraj,
I noticed you are talking about the layer level geometry functions, which
hasn't been updated in the C# bindings yet. I'll add the necessary
implementation shorly. Also added a ticket to track the changes:
http://trac.osgeo.org/gdal/ticket/5264
Best regards,
Tamas
2013/10/10 Dheeraj Reddy Mamidi <drmamidi at rothwellgroup.com>
> Tamas,
> Sorry the sample code had wrong data source names. Here is the corrected
> sample code..
> var spatialReference = new OSGeo.OSR.SpatialReference("");
> spatialReference.ImportFromProj4("+proj=longlat +ellps=WGS84 +datum=WGS84
> +no_defs");
> var driver = OSGeo.OGR.Ogr.GetDriverByName("ESRI Shapefile");
> DataSource dataSourceToIntersectOn =
> driver.Open(@"C:\Temp\gdal_32\Polygon.shp", 0);
> Layer layerToIntersectOn = dataSourceToIntersectOn.GetLayerByIndex(0);
> DataSource dataSourceToIntersect =
> driver.Open(@"C:\Temp\gdal_32\Polyline.shp", 0);
> Layer layerToIntersect = dataSourceToIntersect.GetLayerByIndex(0);
> var intersectedShapeData = driver.CreateDataSource(@"C:\Temp\gdal_32", new
> string[] { });
> wkbGeometryType wkbGeometryType =
> layerOriginal.GetLayerDefn().GetGeomType();
> Layer intersectedLayer = intersectedShapeData.CreateLayer("intersection",
> spatialReference, wkbGeometryType, new string[] { });
> OSGeo.OGR.SWIGTYPE_p_void callback_data = new
> OSGeo.OGR.SWIGTYPE_p_void(new IntPtr(5), false, layerToIntersect);
> OSGeo.OGR.SWIGTYPE_p_GDALProgressFunc callback = new
> SWIGTYPE_p_GDALProgressFunc(new IntPtr(5), false, layerToIntersect);
> layerToIntersect.Intersection(layerToIntersectOn, intersectedLayer, new
> string[] { "SKIP_FAILURES=YES" }, callback, callback_data); // Line where
> it fails
> Thanks,
> Dheeraj
> On Thu, Oct 10, 2013 at 1:16 PM, Dheeraj Reddy Mamidi <
> drmamidi at rothwellgroup.com> wrote:
>> Hi Tamas,
>> Thanks for your response. In fact I don't require progress notification,
>> but I am not able to ignore those arguments (pass them as null). If I pass
>> them as null I get error "Attempt to dereference null GDALProgressFunc". If
>> I just pass those arguments initializing them they way I am doing below in
>> the sample code, I get  "Attempted to read or write protected memory.
>> This is often an indication that other memory is corrupt." error.
>> I am using Gdal 1.10 library.
>> Here is the sample code..
>> +no_defs");
>> Layer layerToIntersectOn = dataSourceCookieCutter.GetLayerByIndex(0);
>> Layer layerToIntersect = dataSourceOriginal.GetLayerByIndex(0);
>> new string[] { });
>> it fails
>> The data that I am trying to intersect (shapefiles are attached).
>> Thanks,
>> Dheeraj
>> On Thu, Oct 10, 2013 at 12:33 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>> Dheeraj,
>>> I don't think the OSGeo.OGR.Layer.Intersection supports progress
>>> notification. You might probably have encountered a bug which should be
>>> fixed. Do you have a sample code to reproduce this issue? I would
>>> specifically interested in the actual geometries have been passed to the
>>> function.
>>> Best regards,
>>> Tamas
>>>> Hi list,
>>>>  I have troubles with C# bindings of OGR. I was trying to perform
>>>> intersection on two feature classes (shape file formats) using
>>>> OSGeo.OGR.Layer.Intersection(), but have problems making it work. I
>>>> keep getting an error saying "AccessViolationException was unhandled.
>>>> Attempted to read or write protected memory. This is often an indication
>>>> Is the above error something to do with SWIGTYPE_p_GDALProgressFunc
>>>> callback and OSGeo.OGR.SWIGTYPE_p_void callback_data arguments? I
>>>> tried passing those parameters null as suggested by some in the forums butI keep getting the error "Attempt to dereference
>>>> null GDALProgressFunc". I am not sure what that means.
>>>> And when I instantiate callback as new SWIGTYPE_p_GDALProgressFunc()
>>>> and new callback_data as new SWIGTYPE_p_void(), I don't get error Attempt
>>>> to dereference null GDALProgressFunc, but still have error saying AccessViolationException
>>>> was unhandled. Attempted to read or write protected memory. This is often
>>>> Can someone please help me figure this out and let me know how to make
>>>> use of OSGeo.OGR.Layer.Intersection() in the right way with c#
>>>> bindings. Thank you.
>>>> Thanks,
>>>> Dheeraj
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131010/965e8def/attachment-0001.html>
