[gdal-dev] OGRLayer.Intersection() question
Tamas Szekeres
szekerest at gmail.com
Fri Oct 11 02:19:22 PDT 2013
Dheeraj,
The issue is now fixed in trunk and branch-1-10 (check out the latest
sources)
I've also added a sample application for these methods:
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/OGRLayerAlg.cs
Best regards,
Tamas
2013/10/10 Dheeraj Reddy Mamidi <drmamidi at rothwellgroup.com>
> Tamas,
> I appreciate you adding a ticket for this issue. Thanks. Is there any
> other option for me to use OGRLayer intersection with out C# bindings for
> now ?
> Thanks,
> Dheeraj
> On Thu, Oct 10, 2013 at 2:21 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Dheeraj,
>> I noticed you are talking about the layer level geometry functions, which
>> hasn't been updated in the C# bindings yet. I'll add the necessary
>> implementation shorly. Also added a ticket to track the changes:
>> http://trac.osgeo.org/gdal/ticket/5264
>> Best regards,
>> Tamas
>>> Tamas,
>>> Sorry the sample code had wrong data source names. Here is the corrected
>>> sample code..
>>> var spatialReference = new OSGeo.OSR.SpatialReference("");
>>> spatialReference.ImportFromProj4("+proj=longlat +ellps=WGS84
>>> +datum=WGS84 +no_defs");
>>> var driver = OSGeo.OGR.Ogr.GetDriverByName("ESRI Shapefile");
>>> DataSource dataSourceToIntersectOn =
>>> driver.Open(@"C:\Temp\gdal_32\Polygon.shp", 0);
>>> Layer layerToIntersectOn = dataSourceToIntersectOn.GetLayerByIndex(0);
>>> DataSource dataSourceToIntersect =
>>> driver.Open(@"C:\Temp\gdal_32\Polyline.shp", 0);
>>> Layer layerToIntersect = dataSourceToIntersect.GetLayerByIndex(0);
>>> var intersectedShapeData = driver.CreateDataSource(@"C:\Temp\gdal_32",
>>> new string[] { });
>>> wkbGeometryType wkbGeometryType =
>>> layerOriginal.GetLayerDefn().GetGeomType();
>>> Layer intersectedLayer =
>>> intersectedShapeData.CreateLayer("intersection", spatialReference,
>>> wkbGeometryType, new string[] { });
>>> OSGeo.OGR.SWIGTYPE_p_void callback_data = new
>>> OSGeo.OGR.SWIGTYPE_p_void(new IntPtr(5), false, layerToIntersect);
>>> OSGeo.OGR.SWIGTYPE_p_GDALProgressFunc callback = new
>>> SWIGTYPE_p_GDALProgressFunc(new IntPtr(5), false, layerToIntersect);
>>> layerToIntersect.Intersection(layerToIntersectOn, intersectedLayer, new
>>> string[] { "SKIP_FAILURES=YES" }, callback, callback_data); // Line where
>>> it fails
>>> Thanks,
>>> Dheeraj
>>> On Thu, Oct 10, 2013 at 1:16 PM, Dheeraj Reddy Mamidi <
>>> drmamidi at rothwellgroup.com> wrote:
>>>> Hi Tamas,
>>>> Thanks for your response. In fact I don't require progress
>>>> notification, but I am not able to ignore those arguments (pass them as
>>>> null). If I pass them as null I get error "Attempt to dereference null
>>>> GDALProgressFunc". If I just pass those arguments initializing them
>>>> they way I am doing below in the sample code, I get "Attempted to
>>>> read or write protected memory. This is often an indication that other
>>>> memory is corrupt." error.
>>>> I am using Gdal 1.10 library.
>>>> Here is the sample code..
>>>> Layer layerToIntersectOn = dataSourceCookieCutter.GetLayerByIndex(0);
>>>> Layer layerToIntersect = dataSourceOriginal.GetLayerByIndex(0);
>>>> new string[] { });
>>>> it fails
>>>> The data that I am trying to intersect (shapefiles are attached).
>>>> Thanks,
>>>> Dheeraj
>>>> On Thu, Oct 10, 2013 at 12:33 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>> Dheeraj,
>>>>> I don't think the OSGeo.OGR.Layer.Intersection supports progress
>>>>> notification. You might probably have encountered a bug which should be
>>>>> fixed. Do you have a sample code to reproduce this issue? I would
>>>>> specifically interested in the actual geometries have been passed to the
>>>>> function.
>>>>> Best regards,
>>>>> Tamas
>>>>>> Hi list,
>>>>>> I have troubles with C# bindings of OGR. I was trying to perform
>>>>>> intersection on two feature classes (shape file formats) using
>>>>>> OSGeo.OGR.Layer.Intersection(), but have problems making it work. I
>>>>>> keep getting an error saying "AccessViolationException was
>>>>>> unhandled. Attempted to read or write protected memory. This is often an
>>>>>> indication that other memory is corrupt.
>>>>>> Is the above error something to do with SWIGTYPE_p_GDALProgressFunc
>>>>>> callback and OSGeo.OGR.SWIGTYPE_p_void callback_data arguments? I
>>>>>> tried passing those parameters null as suggested by some in the forums butI keep getting the error "Attempt to dereference
>>>>>> null GDALProgressFunc". I am not sure what that means.
>>>>>> And when I instantiate callback as new SWIGTYPE_p_GDALProgressFunc()
>>>>>> and new callback_data as new SWIGTYPE_p_void(), I don't get error Attempt
>>>>>> to dereference null GDALProgressFunc, but still have error saying AccessViolationException
>>>>>> was unhandled. Attempted to read or write protected memory. This is often
>>>>>> an indication that other memory is corrupt.
>>>>>> Can someone please help me figure this out and let me know how to
>>>>>> make use of OSGeo.OGR.Layer.Intersection() in the right way with c#
>>>>>> bindings. Thank you.
>>>>>> Thanks,
>>>>>> Dheeraj
>>>>>> _______________________________________________
>>>>>> gdal-dev mailing list
>>>>>> gdal-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Software Developer
> The Rothwell Group, L.P.
> Email: drmamidi at rothwellgroup.com <atvaughan at rothwellgroup.com>
> Phone: 713-952-5355 ext.30
> Web: www.rothwellgroup.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131011/5c56fad5/attachment-0001.html>
