[gdal-dev] Heap corruption when using GDALDriver.CreateCopy (C# Bindings, 1.9.2)
Tamas Szekeres szekerest at gmail.com
Wed Oct 16 02:49:19 PDT 2013
I've tried your project with my compilation of gdal and it did not crash
(created a tif file with ~1.5GB in size). There might be an issue with your
binary set. You might want to try one of the prebuilt binary packages from
http://www.gisinternals.com/sdk/
Best regards,
Tamas
2013/10/16 lightxx <t-h at t-h.cc>
> I would be very glad if somebody would like to try to reproduce the
> behavior
> I'm seeing. I've uploaded a minimum working Visual Studio 2012 solution to
> http://kraxn.t-h.cc/GDALBug.zip . The archive is rather large (200MB)
> because it includes the source file I'm trying to convert ....
> http://osgeo-org.1560.x6.nabble.com/Heap-corruption-when-using-GDALDriver-CreateCopy-C-Bindings-1-9-2-tp5083834p5083837.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131016/1a2e88af/attachment.html>
