[gdal-dev] Heap corruption when using GDALDriver.CreateCopy (C# Bindings, 1.9.2)
Tamas Szekeres szekerest at gmail.com
Wed Oct 16 12:56:02 PDT 2013
In order to avoid mixed CRT dependencies the developers should select the
packages to match with their favourite compiler they are using actually.
Another reason is to provide test environments for gdal and mapserver to
make sure the projects can build equally well in the various compiler
versions / architectures. At the time when
gisinternals<http://www.gisinternals.com/sdk/>have been set up (in
2009) we didn't have any other alternatives to obtain
x64 builds for these OSGeo projects, and this is also the case at the
moment since osgeo4w-x64 is still experimental.
Tamas
2013/10/16 Thomas Heuberger <t-h at t-h.cc>
> just out of curiosity, why are there versions compiled with VC2k3 / 2k5 /
> 2k8 /  2k10? Why not just say 2k10?
> On Wed, Oct 16, 2013 at 4:02 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> It's already in my TODO list (
>> https://github.com/gisinternals/buildsystem/issues/9), but I still
>> didn't have enough free time to work that out.
>> Best regards,
>> Tamas
>> 2013/10/16 lightxx <t-h at t-h.cc>
>>> never mind. I still had that NuGet Post-build event hook in place which
>>> replaced the dlls from the download with the NuGet ones that caused the
>>> exception. Everything's working now, although I'd VERY MUCH prefer to use
>>> the NuGet version.
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/Heap-corruption-when-using-GDALDriver-CreateCopy-C-Bindings-1-9-2-tp5083834p5083868.html
>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131016/39d8e01d/attachment.html>
