[gdal-dev] Sharing GDAL Dataset objects between threads (JNI)
Markus Schneider
schneider at occamlabs.de
Fri Oct 18 07:31:58 PDT 2013
Thanks again.
I found the comments in gdaldataset.cpp, and understand now that there's
no gain in using GDALOpenShared over GDALOpen in a multi-threaded
environment, as GDALOpenShared will create multiple GDALDataset objects
anyway in such a scenario.
Best regards,
Markus
Am 17.10.2013 13:27, schrieb Even Rouault:
> Selon Markus Schneider <schneider at occamlabs.de>:
>> Hi Even,
>> thanks for you help so far.
>> I now observed that handing around a (ECW) Dataset between threads works
>> fine, as long as I open it using:
>> - gdal.Open(String name)
>> However, when I open it using:
>> - gdal.OpenShared(String name)
>> I see strange effects and VM crashes.
>> Does this make sense?
> Yes, GDALOpenShared() ( see the doc of the C function ) must be used with great
> caution in a multi-threaded scenario. As long as the thread that has called
> GDALOpenShared() continues to use it until it closes it, it is OK. But if that
> thread handles the dataset to another one, then chaos might happen.
> For example in the following scenario :
> Thread 1 Thread 2
> ds1 = OpenShared("foo")
> -- handle it to -->
> ds2 = OpenShared("foo") ( == ds1)
> do_things(ds2) do_things(ds1)
> ds2.Close()
> ds1.Close()
> At a point, you can call methods on the same dataset object from different
> threads...
> By the way, the issue you've observed with ECW would also be true with other
> drivers. It is just by chance that you didn't notice it.
>> What do you believe is preferrable with regard to
>> performance and memory consumption:
>> 1. Using a ThreadPool and obtain a Dataset using gdal.OpenShared for
>> each thread
>> 2. Using gdal.Open and simply pool the obtained Dataset objects (and
>> hand them around between threads)
> I'm not sure to completely understand what you've in mind, but I would rather
> recommand option 2.
> Best regards,
> Even
Markus Schneider
CEO
Occam Labs UG (haftungsbeschränkt)
Godesberger Allee 139
53175 Bonn, Germany
+49 228 93798874
http://www.occamlabs.de
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131018/89f96766/attachment.pgp>
