[gdal-dev] Using VRTDataSource/UnionLayer for S57 thematic layers
Andre Vautour
andre.vautour at caris.com
Fri Oct 18 07:29:10 PDT 2013
Hi all,
I recently updated to GDAL 1.10.1 and I am looking into possibly using
the VRT data source to have a data source with S57 thematic layers (e.g.
skin of the earth, obstructions, etc.) instead of one layer per object
acronym (feature). I have a collection of ENC files, so my current .vrt
file looks something like:
<OGRVRTDataSource>
<OGRVRTUnionLayer name="SkinOfTheEarth">
<OGRVRTLayer name="SOMEENC_DEPARE">
<SrcDataSource relativeToVRT="1"
shared="1">someEnc.000</SrcDataSource>
<SrcLayer>DEPARE</SrcLayer>
</OGRVRTLayer>
<OGRVRTLayer name="SOMEENC_LNDARE">
<SrcLayer>LNDARE</SrcLayer>
</OGRVRTLayer>
<OGRVRTLayer name="SOMEOTHERENC_DEPARE">
shared="1">someOtherEnc.000</SrcDataSource>
</OGRVRTLayer>
<OGRVRTLayer name="SOMEOTHERENC_LNDARE">
</OGRVRTLayer>
</OGRVRTUnionLayer>
<OGRVRTUnionLayer name="Obstructions">
<OGRVRTLayer name="SOMEENC_WRECKS">
<SrcLayer>WRECKS</SrcLayer>
</OGRVRTLayer>
</OGRVRTUnionLayer>
</OGRVRTDataSource>
Each thematic layer has several object acronyms. Each thematic layer has
several S57 sources from which to retrieve those acronyms (layers).
Having to specify each individual contributing layer with its source
separately, while very flexible, is fairly verbose and error-prone in my
particular case. Is there a way to specify wildcards/rules for the
sources/layers to load? If not, has such an approach been considered?
Also, is there a way to create a union layer without going through the
VRT file format? That is, through the OGR API, is there a way for a
client application to union layers that it already opened?
Thanks,
André
