[gdal-dev] Postgis Raster issue
Yves Jacolin (Free) yjacolin at free.fr
Tue Oct 22 08:53:27 PDT 2013
Hello,
I am playing with QGIS and raster date in postgis. I get somme error which get
me going to frmts/postgisraster/postgisrasterrasterband.cpp:469.
>From QGIS I get "Warning: RasterIO error: Error retrieving raster data from
database" error message which come from GDAL.
If I read the postgresql log I get:
2013-10-22 17:38:47 CEST STATEMENT:  SELECT st_band(rast, 1), st_width(rast),
st_height(rast), st_bandpixeltype(rast, 1), st_bandnodatavalue(rast, 1),
st_scalex(rast), st_scaley(rast), st_upperleftx(rast), st_upperlefty(rast)
FROM raster.mnt250 WHERE st_intersects(rast,
st_polygonfromtext('POLYGON((89875,00000000000000000
7120125,00000000000000000, 4789875,00000000000000000
2720125,00000000000000000, 89875,00000000000000000 2720125,00000000000000000,
89875,00000000000000000 7120125,00000000000000000))', 2154))
Which is incorrect (check the decimal caracter) and is create on l.469 in the
cpp file.
My gdal is quiet old and is a 1.10dev (not 1.10 stable). As I can't build
again 1.10 stable or trunk, I wondering if it was something known.
Thanks,
Y.
PS : I tried to build gdal 1.10 and master and get this issue:
make[2]: entrant dans le répertoire «
/home/yjacolin/Documents/Dev/gdal/1.10/gdal/frmts/ogdi »
/bin/bash /home/yjacolin/Documents/Dev/gdal/1.10/gdal/libtool --mode=compile
--tag=CXX g++ -g -O2 -msse -DHAVE_SSE_AT_COMPILE_TIME  -Wall  -
I/home/yjacolin/Documents/Dev/gdal/1.10/gdal/port -
I/home/yjacolin/Documents/Dev/gdal/1.10/gdal/gcore -
I/home/yjacolin/Documents/Dev/gdal/1.10/gdal/alg -
I/home/yjacolin/Documents/Dev/gdal/1.10/gdal/ogr -
I/home/yjacolin/Documents/Dev/gdal/1.10/gdal/ogr/ogrsf_frmts -
I/usr/include/ogdi  -DOGR_ENABLED -
I/home/yjacolin/Documents/Dev/gdal/1.10/gdal/port  -c -o ../o/ogdidataset.lo
ogdidataset.cpp
libtool: compile:  g++ -g -O2 -msse -DHAVE_SSE_AT_COMPILE_TIME -Wall -
I/home/yjacolin/Documents/Dev/gdal/1.10/gdal/port -c ogdidataset.cpp  -fPIC -
DPIC -o ../o/.libs/ogdidataset.o
In file included from /usr/include/ogdi/ecs.h:353:0,
                 from ogdidataset.cpp:32:
/usr/include/ogdi/ecs_util.h:108:22: fatal error: projects.h: No such file or
directory
compilation terminated.
make[2]: *** [../o/ogdidataset.lo] Erreur 1
make[2]: quittant le répertoire «
make[1]: *** [ogdi-install-obj] Erreur 2
make[1]: quittant le répertoire «
/home/yjacolin/Documents/Dev/gdal/1.10/gdal/frmts »
make: *** [frmts-target] Erreur 2
