[gdal-dev] Open BIL, BIP, and BSQ raster files without header
Gabriel Fusca
gabrielfusca at suremptec.com.ar
Tue Oct 22 10:43:50 PDT 2013
I'm thinking to configure the header file (.hdr) following the
especification of the header (
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=BIL,_BIP,_and_BSQ_raster_files
skipbytes: file offset
bandrowbytes: band offset
totalrowbytes: row offset
I don't know if GDAL can handle this configuration.
2013/10/22 Kyle Shannon <kyle at pobox.com>
> Gabriel,
> Did you look at the VRT dataset?
> http://www.gdal.org/gdal_vrttut.html
> I suspect that is what you are looking for.
> kss
> On Tue, Oct 22, 2013 at 7:27 AM, Gabriel Fusca
> <gabrielfusca at suremptec.com.ar> wrote:
> > Dear all,
> > I'm using GDAL 1.9.1 and I would like to load binary raster files
> > especifying manually header information such number of lines, number of
> > pixels, pixel data type, byte order, bits per pixel.
> > Also I would like to specify file offset, band offset and line offset for
> > the file.
> > Can someone please help me figure this out.
> > Thanks in advance,
> > Regards
> > Gabriel Fusca
> > SUR Emprendimientos Tecnológicos
> > Perú 345 Piso 5to Oficina "B" (C1067AAG)
> > Ciudad de Buenos Aires, Argentina
> > Tel. +54 (11) 4342-2976/84
> > http://www.suremptec.com/
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Kyle
Gabriel Fusca
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131022/a6549aa2/attachment.html>
