[gdal-dev] ReprojectImage and nodata
David Shean dshean at gmail.com
Wed Oct 23 12:19:48 PDT 2013
Even,
I encountered the issue you mention back in May:
http://osgeo-org.1560.x6.nabble.com/gdal-dev-ReprojectImage-and-nodata-td5057270.html
The current ReprojectImage nodata handling is a bit confusing.  Do you see a relatively simple fix to mirror the behavior of gdalwarp?
Thanks.
-David
On Oct 23, 2013, at 10:25 AM, Even Rouault <even.rouault at mines-paris.org> wrote:
> Le mercredi 23 octobre 2013 19:05:18, Ochs, Elke ERDC-RDE-CRREL-NH a écrit :
>> ReprojectImage does not maintain areas of nodata as I would expect it
>> should.  Small areas of nodata are getting erased and larger areas are
>> reduced in size.  I'm reprojecting from geographic to Albers, using
>> approximately the same  cell size (converted from dd to meters).  I'm
>> using GDAL 1.9.2 in Python.
>> Gdalwarp does a better job of maintaining nodata cells.  Is there a way to
>> get ReprojectImage to handle nodata in a similar way?
> Elke,
> Always difficult to diagnose those problems as there are a few variables to
> consider.
> Looking at the code of GDALReprojectImage(), I see it should take into account
> the source nodata value, but it will ignore the nodata value that you may have
> set on the target dataset, contrary to gdalwarp. That might be your issue.
> Your source nodata values are likely to become 0 in the target datasource.
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
