[gdal-dev] GTiff stack to NetCDF
David Shean
dshean at gmail.com
Mon Sep 2 15:09:45 PDT 2013
Hi list,
I'm trying to package a timeseries of GTiff rasters with identical projection/extent/resolution as a single NetCDF file for distribution. I've spent the past hour consulting the online doc and playing with gdal_translate, gdalbuildvrt and gdalwarp without any success.
Is there an easy way to do this using existing gdal command line utilities? I figured I'd ask before resorting to a custom solution using the NetCDF Python API.
Thanks.
-David
