[gdal-dev] HFA and RAT
Ivan Lucena
lucena_ivan at hotmail.com
Tue Sep 3 13:22:14 PDT 2013
Take any image, a screenshot of your desktop for example, save it as .bmp "gdal_translate" it to HFA, .img file, and run gdalinfo on it (trunk version). It's only me or at the end of the gdalinfo report do you also see <GDALRasterAttributeTable /> for each band?
Band 1 Block=64x64 Type=Byte, ColorInterp=Undefined
Description = Layer_1
Metadata:
LAYER_TYPE=athematic
Band 2 Block=64x64 Type=Byte, ColorInterp=Undefined
Description = Layer_2
Metadata:
Band 3 Block=64x64 Type=Byte, ColorInterp=Undefined
Description = Layer_3
Metadata:
It seems to me that the HFA driver is reporting incorrectly when the GDAL API function GDALGetDefaultRAT is called by gdalinfo.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130903/f3f3cd51/attachment.html>
