[gdal-dev] A strange thing with a png geospatial file and gdalwarp. Is it a bug?
peifer peifer at gmx.eu
Wed Sep 4 06:30:23 PDT 2013
aborruso wrote
> I have changed only the file format, and I obtain different results.
> Is this normal?
It is "normal", because more than the format has been changed. Compare the
CRS definitions in png vs. tif and you'll find and additional extension
definition in the tif:
EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs"]
The above "auto-correction" includes the +nadgrids=@null parameter, which in
return avoids the "change of ellipsoid" step in the transformation.
Hermann
View this message in context: http://osgeo-org.1560.x6.nabble.com/A-strange-thing-with-a-png-geospatial-file-and-gdalwarp-Is-it-a-bug-tp5075948p5076013.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
