[gdal-dev] gdal_translate -outsize resampling method?
Eloi
eloi at openmailbox.org
Fri Sep 6 03:34:32 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 09/06/2013 12:21 PM, Jukka Rahkonen wrote:
> Eloi <eloi <at> openmailbox.org> writes:
>> Hi all,
>> What is the resampling method used by gdal_translate when using
>> the -outsize option?
> Nearest neighbor. Use gdalwarp if you want to use some other
> resampling.
> -Jukka Rahkonen-
Thanks!
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJSKa+4AAoJEP9qulIE6g+yOCwH/0o1JDdWp5+0xQDTQ7NdXTSl
jQ9DsMu2qEp5h/k/9O2pt2DXHdJ43xh+TkYLkle3lPhBX/nslsRLLVRfu77Oz5/0
DNj5t8zJfsUIAD7HzJGGu046Eo0Y+Q+OgH5/AazcyYPev9krd+ufBEmw4bZTBqr5
Bz6p7nazX8WK37pIJBDca3pij+3nXCeTZmkmtpYHVt9/uZvS0oE65a0eczkLTxxt
jlw9/K422ZvqclnOuOpN9Msn2jxpI5Lat6EuDUR+WF2EXhAtmhIIqVAuWsVhWUq9
JavMk5XMRG11KN0D3Ii1F8OZLY3adKvAsSxY4ipzM2IHLyk5EGpFvqL2VPsEPi4=
=DcBp
-----END PGP SIGNATURE-----
