[gdal-dev] MOD13C2 assign coord. sist.
Eloi eloi at openmailbox.org
Fri Sep 6 04:58:44 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 09/06/2013 01:38 PM, Jose Gomez-Dans wrote:
> On 6 September 2013 11:33, Eloi <eloi at openmailbox.org> wrote:
>> Assigning EPSG:4326 nothing comes up when loading the image with
>> others data in EPSG:4326.
> You are right, the data is missing georeference information: $
> gdalinfo
> 'HDF4_EOS:EOS_GRID:"MOD13C2.A2000032.005.2006272104028.hdf":MOD_Grid_monthly_CMG_VI:CMG
0.05 Deg Monthly NDVI'
> [snip snip snip] Corner Coordinates: Upper Left  (  -1.0000000,
> -1.0000000) Lower Left  (  -1.0000000,  -1.0000000) Upper Right (
> -1.0000000,  -1.0000000) Lower Right (  -1.0000000,  -1.0000000)
> Center      (  -1.0000000,  -1.0000000)
> So you are right, you need to specify it. This works $
> gdal_translate -of GTiff  -a_srs "EPSG:4326" -a_ullr -180 90 180
> -90 \
0.05 Deg Monthly NDVI' ndvi.tif
> Cheers, Jose
Yes, but is this the right way of doing it? Because basically with
a_llur option the image is being gereferenced and it may create some
distortions, I am correct? Nevertheless the result is quit good.
Eloi
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJSKcN0AAoJEP9qulIE6g+ypTEH/1rFCnQ45ozg0UU/RALA9eem
a36Vxa9DARXZF3t5+uLhDsKybsB/PcXlSGLRuaWifhWyouQJukAS9FE99/D0D0q3
fUtXyfg1MTBM/cuIryjDT18zebzX9HfdKfe0WnY6Kum8WYxQzzllfLSIwplHl4XF
oS0q9Oi9/CNJB4YbU+xbQie8xFOT/29g2fdiMxTxSe0Zgn+5Hqn2QUXEQOD9cpd7
zYDYMCvQPYh3+lRdo6cZN9auZn47Is8sLi+91S6/Ng8UL9g8faMq9ITYDXZwRYuQ
TcBBtFCosbAB9to18fbnalRzo5QPhECck1Mz0zmIj0j23McMbBfyWKQoY5LcMT4=
=3rrM
-----END PGP SIGNATURE-----
