[gdal-dev] GDAL DLL and plugin with mixed compiler versions
Tamas Szekeres szekerest at gmail.com
Sat Sep 7 10:55:06 PDT 2013
Carl,
I don't see CRT dependencies in the dll-s provided by the MrSID SDK so it
might less likely be an issue if you link against their the libs in a
VS2012 compilation. I also wanted to add VS2012 packages at
http://www.gisinternals.com/sdk/ but I didn't have enough spare time so far
to complete this effort.
Best regards,
Tamas
2013/9/7 Carl Godkin <cgodkin at gmail.com>
> I agree with Tamas that you are going to have hard-to-isolate problems
> mixing compiler versions.  I have sort of a similar problem and I'm going
> to partially hijack this thread to see if anyone has any suggestions:
> We use the latest version of GDAL we can (about to upgrade to 10.0.1) and
> try to use the latest compilers. Currently we build with gcc 4.4 and VS
> 2010 although we are eager to upgrade to gcc 4.6 and VS 2012.  However, I
> don't think we can do so because we need MrSID support from GDAL and they
> (LizardTech) only support up to gcc 4.4 and VS 2010 with their DSDK and I
> want to avoid the mixed-compiler problems we're warning David about.
> Has anyone figured out a way to work around this limitation?
> Thanks very much,
> carl
> On Sat, Sep 7, 2013 at 3:21 AM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> David,
>> You should anyway use a consistent build along your system or make sure
>> you use your own version of gdal dll which is compatible with your plugin.
>> Mixing dependencies from different sources, compiled by different version
>> may cause unpredictable issues and crashes. You may either think to upgrade
>> your dll for VS2008 or isolate your application to load your specific
>> version. Not sure how that can be done technically without a more detailed
>> description of your software components/architecture.
>> Best regards,
>> Tamas
>> 2013/9/6 David Szlucha <David.Szlucha at exelisvis.com>
>>> I have a GDAL plugin that is built with VS 2005 SP1 that I’m trying to
>>> use with a GDAL 1.8 DLL that was built with VS 2008. I cannot rebuild the
>>> GDAL 1.8 DLL as it is provided by a different vendor/application.****
>>> I’ve found that the GDAL utilities crash when they are exiting (as well
>>> as some functionality in the vendor/application that our plugin was built
>>> for) in Windows 7. This does not seem to be a problem in Windows XP. ***
>>> I have limited information in the debugger but I suspect the issue might
>>> be in the GDAL driver manager deconstructor as I have created a “dummy”
>>> GDAL plugin that simply registers itself as a plugin and does nothing else
>>> and exhibits the same crash.****
>>> After some internet searching it looks as if this problem has occurred
>>> with other GDAL plugins and the solution was to rebuild the plugin using
>>> the same compiler that built the GDAL DLL.****
>>> Since my project consists of several other DLLs that I can’t readily be
>>> updated to VS 2008 I’m wondering if anyone has come across this issue in
>>> their own plugins and may have attempted to fix the issue with mixed
>>> compiler versions?****
>>> Thanks!****
>>> David****
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130907/ef201986/attachment-0001.html>
