[gdal-dev] [Qgis-developer] QGIS 2.0.0 Final Tagged - call for
Jeremy Palmer JPalmer at linz.govt.nz
Mon Sep 9 13:19:06 PDT 2013
Hi GDAL devs,
It is possible get the OSGeo4W 32bit GDAL 1.10 binary packaged soon?
Thanks
Jeremy
>> On Mon, 09. Sep 2013 at 20:56:51 +1200, Jeremy Palmer wrote:
>> Can I suggest to the windows packagers (especially OSGeo4w admins) that QGIS
>> is linked to gdal 1.10 so Esri FileGDB support works. I see only the testing
>> 64bit OsGeo4w distribution has built gdal 1.10, so the gdal OSGeo4w
>> maintainers might need a nudge to build it in the 32bit release version :)
> We windows qgis packagers (me, myself and I) are going to use what currently is
> in osgeo4w.
> As far as I know there will be a GDAL 1.10.1.1 release soon.  I'm going to
> update the 64bit gdal with that and Frank Warmerdam will update OSGeo4W 32bit
> (but there's no known timeframe for that - maybe he finds time on FOSS4G).
> J?rgen
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
