[gdal-dev] Extracting (arbitrary?) overviews from ECW file
Markus Schneider
schneider at occamlabs.de
Tue Sep 10 02:13:08 PDT 2013
I believe I learned how to do this, so to answer my own question:
Some of the Band.ReadRaster(...) methods allow to explictly specify the
buffer width and height, e.g. [1]. This allows to extract resolutions
that differs from the original image (and the overviews).
Best regards,
Markus
[1] http://gdal.org/java/org/gdal/gdal/Band.html#ReadRaster(int, int,
int, int, int, int, int, byte[])
Am 05.09.2013 18:01, schrieb Markus Schneider:
> Frank,
> thanks for your reply. Could you (or somebody else) give me a few more
> details how to get hold of a raster region with a resolution that is not
> defined by an overview?
> Currently, I am able to extract regions from an overview using the
> following steps (in Java):
> Dataset dataset = gdal.Open( "dataset.ecw", GA_ReadOnly );
> Band band = dataset.GetRasterBand( ... );
> band = band.GetOverview(...);
> band.ReadRaster(x,y, ...)
> Afterwards, I have the raw data values in my array. It works fine for
> any overview.
> My problem is that I cannot figure out how to get hold of a Band for a
> non-predefined overview. How would I do this?
> Best regards,
> Markus
> Am 04.09.2013 18:15, schrieb Frank Warmerdam:
>> Markus,
>> I believe the GDAL ECW driver will pass RasterIO() requests through to
>> the ECW SDK to evaluate meaning that there is no constraint based on the
>> advertized power-of-two overviews exposed from GDAL and no loss of quality.
>> Best regards,
>> Frank
>> On Wed, Sep 4, 2013 at 6:52 AM, Markus Schneider <schneider at occamlabs.de
>> <mailto:schneider at occamlabs.de>> wrote:
>> Dear list,
>> I am new to programming with GDAL (and to the ECW format). Let me say
>> thank you first, because my first experiences have been rather pleasant,
>> even if my setup is relatively involved (thanks everybody for providing
>> good documentation):
>> - Ubuntu 12.04 (AMD64)
>> - GDAL 1.10.1 (build from source)
>> - ECW SDK 5.0
>> - GDAL Java bindings
>> I successfully created a toy Java class for extracting regions from an
>> ECW file. Speed is impressive.
>> My observations/questions:
>> - If I understand correctly, ECW files internally do not have such a
>> thing as fixed overviews. However, ECW supports extraction of regions
>> with specified resolution on-the-fly. Is this correct?
>> - GDAL API reports overviews for ECW datasets. Having a first look at
>> the code, it seems to generate overview dimensions by subsequently
>> dividing height and width by two (until a minium side length of 128 has
>> been reached).
>> Final question: Is it possible to efficiently retrieve (regions of)
>> overviews at self-defined scales using the GDAL API? Or do I have to use
>> the ECW SDK for that?
>> Keep up the good work. Thanks for any pointers.
>> Best regards,
>> Markus
>> Markus Schneider
>> CEO
>> Occam Labs UG (haftungsbeschränkt)
>> Godesberger Allee 139
>> 53175 Bonn, Germany
>> +49 228 93798874 <tel:%2B49%20228%2093798874>
>> http://www.occamlabs.de
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> warmerdam at pobox.com <mailto:warmerdam at pobox.com>
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Software Developer
Markus Schneider
CEO
53175 Bonn, Germany
+49 228 93798874
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130910/5c2415a6/attachment.pgp>
