[gdal-dev] ogr2ogr load shape in tablespace
Even Rouault
even.rouault at mines-paris.org
Thu Sep 12 11:17:46 PDT 2013
Le jeudi 12 septembre 2013 14:26:13, Clay, Bruce a écrit :
> I need to load a set of shapefiles into a tablespace (on a different hard
> drive) where I have more dataspace. I have been using ogr2ogr to load
> shapefile up to this point using windows command prompt and batch files.
> I created a tablespace using pgAdminIII but I can not find a way to assign
> the data to the tablespace from ogr2ogr. I googled but did not find a way
> to do so.
> Is there a way not listed in the help function or docs?
Bruce,
I'm just discovering what tablespaces are from the PostgreSQL docs.
There's no direct way of doing this currently, although it doesn't look very
complicated to add support for that.
But you can probably workaround that by using the pgdump driver
ogr2ogr -f pgdump out.sql your.shp
and then edit out.sql to add at its very beginning :
SET default_tablespace = your_tablespace;
and then insert the SQL with the following command (can possibly also be done
with pgAdmin3 I imagine)
psql -d XXXXX -f out.sql
I've not actually tried the above however.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
