Only to add that if I try to read the same MySQL input using OGR Virtual Format, the ST_Area function works properly. Thank you -- View this message in context: http://osgeo-org.1560.x6.nabble.com/sqlite-dialect-and-MySQL-spatial-input-tp5080909p5080911.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
