[gdal-dev] Weird issue when running gdaltranslate
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Tue Apr 1 04:08:23 PDT 2014
<Moses.Gone <at> t-systems.com> writes:
> Hi everyone,
> I am getting this weird error when I try to convert a vrt to a tif.
> Some context: We are tiling a set of tifs(in a list file). First we
generate a vrt from the list. Then we assign a projection on the generated
vrt using gdaltranslate. We then clip the output using gdalwarp applying a
clipping at the same time to the desired
> BBOX(This is achieved using the –te option). In the warp operation we also
specify the target SRS(using the –t_srs option). Lastly we tile using our
customized gdal_retile.py. All is fine with the projection and clipping, but
the resultant tiles are empty-no
> data just white images.
> So I tried to backtrack my steps, to check at what point is the data being
lost. Generation of the VRT works fine. However, performing gdaltranslate to
assign the source SRS on the VRT result into this error:
> bash-2.05$ gdal_translate -of GTiff ffm_dtk200_wdd.vrt test.tif
> Input file size is 2147483647, 2147483647
> 0ERROR 1: GTiffCreateCopy():No space for strip arrays
> ERROR 1: MissingRequired:TIFF directory is missing required "StripOffsets"
field
field
> I tried to also convert to AAIGrid format, thinking that something is
wrong converting to Tiff, but also got this error:
> bash-2.05$ gdal_translate -of AAIGrid ffm_dtk200_wdd.vrt test3
> 0ERROR 1: CPLMalloc(-4): Silly size requested.
> ERROR 1: ffm_dtk200_wdd.vrt, band 1: The buffer into which the data should
be read is null
> Segmentation Fault
> Other tiling jobs following a similar method, with different source data
works fine though. Could the problem be with the data? If so how comes it
worked before?
Perhaps adding -co BIGTIFF could help. Much better though would be better to
skip the whole step of creating a temporary tiff file because it is slow and
unnecessary.
Use buildvrt with -a_srs and resulting vrt contains projection. Even if it
is missing you should be able to tell it directly for gdalwarp as
gdalwarp -s_srs epsg:xxx -t_srs epsg:yyyy -te .... input.vrt output.tif
-Jukka Rahkonen-
