[gdal-dev] Set max value of "1.#IO" in Geotiff to nodata
Even Rouault
even.rouault at mines-paris.org
Wed Apr 2 11:32:51 PDT 2014
Le mercredi 02 avril 2014 02:20:54, Moskovitz, Bob at DOC a écrit :
> Hello gdal,
> I have a set of geotiffs that have a strange max (infinity?) values that I
> would like to set to nodata. These originally were netcdf files. With
> the current of gdal in OSGEO4W, gdalinfo reports:
> gdalinfo -mm pola_cascadiad_sift2_maxspeed.tif
> Driver: GTiff/GeoTIFF
> Files: pola_cascadiad_sift2_maxspeed.tif
> Size is 1810, 1100
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> Origin = (-118.302500000118700,33.779999999966194)
> Pixel Size = (0.000092592592580,-0.000092592592587)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left (-118.3025000, 33.7800000) (118d18' 9.00"W, 33d46'48.00"N)
> Lower Left (-118.3025000, 33.6781481) (118d18' 9.00"W, 33d40'41.33"N)
> Upper Right (-118.1349074, 33.7800000) (118d 8' 5.67"W, 33d46'48.00"N)
> Lower Right (-118.1349074, 33.6781481) (118d 8' 5.67"W, 33d40'41.33"N)
> Center (-118.2187037, 33.7290741) (118d13' 7.33"W, 33d43'44.67"N)
> Band 1 Block=1810x1 Type=Float64, ColorInterp=Gray
> Computed Min/Max=0.000,1.#IO
> I've been converting the geotiff to AAIGrids and replace all "1.#INF" to my
> nodata value, but I'm hoping that there is an easier way to do this with
> GDAL.
With GDAL 1.10, you should be able to specify "-a_nodata inf". But I'm not
completely sure if 1.#IO is the represnetation of infinity. Might be a not-a-
number ?
> Thanks in advance,
> Bob
> Robert Moskovitz
> California Geological Survey
> Seismic Hazards Zonation Program
> CONFIDENTIALITY NOTICE: This communication is intended only for the use of
> the individual or entity to which it is addressed. This message contains
> information from the State of California, California Geological Survey,
> which may be privileged, confidential and exempt from disclosure under
> applicable law, including the Electronic Communications Privacy Act. If
> the reader of this communication is not the intended recipient, you are
> hereby notified that any dissemination, distribution, or copying of this
> communication is strictly prohibited.
Geospatial professional services
http://even.rouault.free.fr/services.html
